2 Pages12>
craigpage
#1 Posted : Monday, August 23, 2010 12:07:43 PM(UTC)
craigpage
GE frontloader washer WSXH208A1WW by Fridgidair
Tumbles but will not go into spin cycle. Coin trap is clean, pump runs & empties drum.
Tested per manual across pin 5 to 9 120V, no V reading between 5 & 1,2,6,10.
Trouble shooter points to timer and control.
Which one needs replaced?
#2 Posted : Monday, August 23, 2010 1:42:29 PM(UTC)
According to the troubleshooting I found (Frigidaire) sounds like the problem is a bad timer. The instructions are attached to the reply.
Is the manual you referred to is GE or Frigidaire?
- The timer Part number: AP2620106
Here are the breakdown diagrams and Replacement parts for General Electric WSXH208A1WW Washer | AppliancePartsPros.com
P.S. If you'll order the timer from Appliance Parts Pros and it would not solve the problem, you can order the motor speed control board and return the timer even if it was installed.
File Attachment(s):
Drive motor tumbles but does not spin.doc (93kb) downloaded 10 time(s).
craigpage
#3 Posted : Monday, August 23, 2010 1:50:53 PM(UTC)
craigpage
Manual is Electrolux. Followed same page you posted in not spin.doc.
Will water presure switch not allow to continue cycle?
#4 Posted : Monday, August 23, 2010 1:53:31 PM(UTC)
I do not think so. More possible a bad door lock switches.
craigpage
#5 Posted : Monday, August 23, 2010 1:58:02 PM(UTC)
craigpage
Is repairing timer possible?
This fault occured after pump got glogged. Cleaned it out, worked again but no spin, timer advances in earlier cycles.
craigpage
#6 Posted : Monday, August 23, 2010 2:02:45 PM(UTC)
craigpage
Is pump supposed to run during spin cycle? Or does spin cycle start after pump stops? My pump does not stop even when empty.
Door lock appears to work correctly, have not tested it, led lights & door locks. Cycle interupts if soap tray is opened.
#7 Posted : Monday, August 23, 2010 2:12:52 PM(UTC)
Originally Posted by: craigpage Go to Quoted Post
...Manual is Electrolux...
Did you find it inside the washer or somewhere else?
If the washer has GE logo and model number on it, the tech sheet must be GE as well.
craigpage
#8 Posted : Monday, August 23, 2010 2:21:48 PM(UTC)
craigpage
Downloaded it, everything about it matches my machine. All the parts have Frigidaire lables. Replaced pump in the past and found it then. The tech pages that came with machine are missing.
craigpage
#9 Posted : Monday, August 23, 2010 3:16:16 PM(UTC)
craigpage
Is this timer the same, except $30 less?
Part Details - FRIGIDAIRE Timer - washer mallor, part number: AP2107661[URL="http://www.appliancepartspros.com/part_details_lgimg.aspx?part_id=2108034&image=0"][/URL]
#10 Posted : Monday, August 23, 2010 6:14:12 PM(UTC)
Most likely such timers are not repairable.
The Frigidaire timer you found looks pretty similar to the GE timer. I would give it a try.
2 Pages12>
