brianyow@centurylink.net
#1 Posted : Monday, August 23, 2010 10:16:26 AM(UTC)
Found terminals burnt on motor. What next?
#2 Posted : Monday, August 23, 2010 10:21:59 AM(UTC)
tub not turning, found burnt terminals on motor. What steps should we take next?
#3 Posted : Monday, August 23, 2010 1:04:51 PM(UTC)
Originally Posted by: brianyow@centurylink.net Go to Quoted Post
...found burnt terminals on motor...
Wire terminals or motor terminals?
What is the complete model number of the dryer?
#4 Posted : Tuesday, August 24, 2010 7:58:54 AM(UTC)
Gene I did not notice this was a duplicate so will just add mine to yours and then will mark the other one.
A model number may help others help you.
Terminal appears to be burnt and the tub is not turning like it should.
A better description of the problem would also help.
What do you mean by "Terminal?
What is burnt?
How is it not turning as it should?
etc.
etc.
Read more: http://forum.appliancepartspros...dryer.html#ixzz0xXVt9tUG
http://forum.appliancepartspros.com
GE Harmony DRYER TUB NOT TURNING WHEN full (Dryer Repair)
by Marci Mainieri 2/12/2010 2:09:06 PM(UTC)
tub not turning and the agitator (Washer Repair)
by the pit 10/8/2008 7:16:05 PM(UTC)
