Ward05
#1 Posted : Sunday, August 22, 2010 5:35:17 PM(UTC)
Ward05
The moisture assembly (AP2107715) came off of the door assembly. the assembly holds the lint filter. when this shappened the two red wires came off. the assembly has what looks like two chrome bars with spade connectors on each end. How do I determine which spade to put the connectors on??? I have two wires and four possible places to put them.
thank you
Ward
#2 Posted : Tuesday, August 24, 2010 7:18:35 AM(UTC)
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134064800e.pdf
It does not matter which end of the strips the wires attach to as long as you have one wire going to each strip.
The way it works is that the board monitors the resistance between the strips.
When totally dry the resistance is infinite (open). When there is moisture between the strips there is a resistance, the board senses this and continues drying the clothes.
Ward05
#3 Posted : Tuesday, August 24, 2010 7:50:33 AM(UTC)
Ward05
Great, thanks for the help and the theory behind it.
GE gtd65ebsj3ws moisture sensor bar (Dryer Repair)
by Guest 11/1/2021 6:13:07 AM(UTC)
moisture sensors gone bad? (Dryer Repair)
by campbell42 4/7/2019 2:28:27 PM(UTC)
GE Adora Dryer Moisture Sensor Replacement (Dryer Repair)
by RedCoat999 12/14/2018 1:38:37 PM(UTC)
GE moisture sensor bars came loose (Dryer Repair)
by Dentbent 6/24/2015 8:52:37 PM(UTC)
DG 612 Moisture Sensor Location? And how to replace? (Dryer Repair)
by GregL564 2/22/2015 6:21:25 AM(UTC)
Whirlpool dryer - moisture sensor noise (Dryer Repair)
by JC_123 3/19/2014 4:21:14 PM(UTC)
Moisture Sensor Connect (Dryer Repair)
by DTdr2 5/29/2013 7:24:13 AM(UTC)
Moisture Sensor Test on Whirlpool Gas Dryer (Dryer Repair)
by skuddle 4/9/2013 10:42:48 AM(UTC)
Whirlpool Gas Dryer Moisture Sensor Access (Dryer Repair)
by skuddle 4/2/2013 11:28:42 AM(UTC)
Maytag Moisture Sensor Test (Dryer Repair)
by Jdfultonii 2/7/2012 3:32:27 PM(UTC)
Wires To Maytag Neptune Moisture Sensor (Dryer Repair)
by Rhythmking 11/30/2011 9:34:06 AM(UTC)
Whirlpol Moisture Sensor Dryer (Dryer Repair)
by Reid Carlson 5/23/2011 7:21:54 AM(UTC)
Moisture sensor burn-out! (Dryer Repair)
by ahjort 2/21/2011 3:39:26 PM(UTC)
Dryer doesn't heat up and moisture sensor not indicating wet clothes (Dryer Repair)
by Joan Cartier 10/3/2010 5:58:52 AM(UTC)
Dryer Moisture Sensor Out (Dryer Repair)
by usbradleys 9/16/2010 10:42:55 AM(UTC)
