I bought a replacement motor for my washer which came with a pully , evidently, permently placed on the shaft. I can not figur out how to get thei motor into the space the old one came out of which had a removable pully. Anybody know how?
[FONT='Times New Roman'] Rotate the transmission until it is in the position to give you the most room. Then lay the motor straight back with the pulley pointing toward you. Push the motor back until the boltholes will line up when you sit the motor back up and it should go right in place. I hope this helps. [/FONT] [FONT='Times New Roman'] [/FONT] [FONT='Times New Roman'] Clothes Washer Repair Guide[/FONT]
Originally Posted by: applianceman Rotate the transmission until it is in the position to give you the most room. Then lay the motor straight back with the pulley pointing toward you. Push the motor back until the boltholes will line up when you sit the motor back up and it should go right in place. I hope this helps. Clothes Washer Repair Guide Thanks a lot it worked!:)
Originally Posted by: ramszhang I bought a replacement motor for my washer which came with a pully , evidently, permently placed on the shaft. I can not figur out how to get thei motor into the space the old one came out of which had a removable pully. Anybody know how? Here are the instructions from the service manual: To Service Motor/Clutch 1 remove front panel,access motor and clutch from front. 2 Loosen (4) 3/8" nuts on leg and platform assembly (underside of platform). 3 Move motor towards the center of the platform to release belt tension,and remove belt. 4 After removing 4 motor mount bolts, rotate transmission to a position that allows you enough clearance to pull the motor out by moving the bottom forward to allow the assembly to clear the platform. 5 The clutch is mounted on top of the motor with a one shot removable clutch spring clip that engages the flats in the motor shaft To remove the clutch, remove the clip and lift the clutch up. 6 Reverse and repeat previous steps to reassemble. Hope this is what you were looking for. :) :) :)
