lynndicken
#1 Posted : Thursday, August 19, 2010 5:13:23 AM(UTC)
lynndicken
The timer usually has to be turned off in a very particular manner or it keeps "ticking" when it reaches 'off'. The clothes will dry, the Timed Dry works best, the Accu-Dry is not reliable. To start the timer, it also has to be turned in a particular direction for it to start -the dial seems to spin in some areas as if it is not engaging. Do I need to purchase a new timer? Thanks.
sidfink43
#2 Posted : Saturday, August 21, 2010 5:42:19 PM(UTC)
sidfink43
This machine has a timer and a circuit board, and given the age of the machine and the cost of the parts I think you should consider a new machine.
A basic dryer will do a great job for you, not cost much more than parts for your old machine and have a warranty and all those good things.
ThatGuy
#3 Posted : Saturday, August 21, 2010 10:30:30 PM(UTC)
ThatGuy
Groups: Expert
United States
It sounds like the timer is bad. Here's the Part number: AP2947073
I guess it depends on what kind of shape the rest of the dryer is in and how much you want to spend on a repair. Ultimately its up to you whether to repair or replace.
