rooger
#1 Posted : Tuesday, August 17, 2010 2:18:55 PM(UTC)
rooger
We have a GE gas range oven that was probably installed in the house when it was built in 2005. The problem, and it is intermittent is that the top burners and the broiler work fine but the bake function no longer works.
i looked at the gas valve behind the warming drawer to ensure the gas valve did not get accidentally shut off per the user guide and it was fine.
any ideas before we make a service call?
Thank yoiu
kayakcrzy
#2 Posted : Wednesday, August 18, 2010 3:38:03 AM(UTC)
kayakcrzy
Thank yoiu
Replace the ignitor coil, and that will do the trick. Tom ApplianceEducator.com - Parts
rooger
#3 Posted : Wednesday, August 18, 2010 9:24:48 AM(UTC)
rooger
Thank you for the quick response!
Does the broiler function and the bake function utilize separate igniter coils? It looked as if there were two on the parts diagram.
The parts diagram on this website identified GE part number AP2014008 "Oven or Broiler Igniter, Round Style" for $64.95 which looks the part you mentioned.
Can this be replaced by the commoner or does it require a professional? I would assume that you'd close the gas valve and replace the part.
Thank you for the information!
Rob
kayakcrzy
#4 Posted : Wednesday, August 18, 2010 2:44:55 PM(UTC)
kayakcrzy
You are correct with the part #, and you don't have to shut the gas off. You can do it. Just unplug the oven.
Guest (4)
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 3/3/2024 10:10:13 AM(UTC)
Frigidaire Gallery Range Oven Won't Get to Temp (Oven Repair (including Ranges and Cooktops))
by Guest 5/5/2023 7:41:56 PM(UTC)
Amana range oven elements stopped working (Oven Repair (including Ranges and Cooktops))
by Primary123 6/8/2022 1:40:04 PM(UTC)
Monogram Range Oven Mod ZGP486LDR4SS (General Talk)
by astringfield 12/29/2021 4:58:36 AM(UTC)
GE gas range oven won’t come on (Oven Repair (including Ranges and Cooktops))
by Guest 6/6/2021 3:02:24 PM(UTC)
Viking range ovens, broiler, and griddle don’t turn on (Oven Repair (including Ranges and Cooktops))
by Guest 5/19/2021 11:02:20 AM(UTC)
Whirlpool range oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by Guest 5/10/2021 12:58:16 PM(UTC)
Range oven problems. (Oven Repair (including Ranges and Cooktops))
by jorge osorio 1/29/2019 1:16:21 PM(UTC)
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Kenmore gas range oven won't work (Oven Repair (including Ranges and Cooktops))
by shirleyjones 12/14/2016 10:41:41 AM(UTC)
Samsung induction range oven not working (Oven Repair (including Ranges and Cooktops))
by Wolf22 8/4/2015 12:11:42 PM(UTC)
Range Oven Not Heating About 300 Degrees (Oven Repair (including Ranges and Cooktops))
by kpaxson 7/16/2015 12:05:23 PM(UTC)
Frigidaire Gallary Electric Range Oven Will Not Turn On (Oven Repair (including Ranges and Cooktops))
by jaycevs 12/2/2014 5:28:35 AM(UTC)
Maytag range oven (Oven Repair (including Ranges and Cooktops))
by C Hardin 10/30/2014 4:23:34 PM(UTC)
