Ronald40
#1 Posted : Thursday, August 12, 2010 1:33:37 PM(UTC)
Ronald40
Dryer has power but, will not start. Timer does not run, drum light does not work, thermal fuse is good. Have any ideas.
Ronald40
#2 Posted : Friday, August 13, 2010 2:06:04 AM(UTC)
Here is a wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203979710.pdf
How do you know that it has power?
Since the unit's drum light has also stopped working it points to either the loss of L1 to Neutral power or the door switch.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Ronald40
#3 Posted : Saturday, August 14, 2010 10:04:25 AM(UTC)
Ronald40
Ronald40
In answer to first question, I used multi-meter to check for power at terminal strip.
I find with door switch pluged in, I get nothing between L1 and L2 I get 240 volts, between L1 and Neutral I get 240 volts, between L2 and Neutral I get nothing.
With door switch unplugged, I get 240 between L1 and L2, 124 between L1 and Neutral and 114 between L2 and Neutral.
Power at recept'l is normal 240 volts between L1 and L2, 120 volts between L1 or L2 to Neutral.
I have checked wires at terminal strip for tightness and condition.
I checked door switch and found to be defective, however, after jumpering door switch unit would start.
Ronald40
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
