mikebaily
#1 Posted : Tuesday, August 10, 2010 10:44:02 AM(UTC)
mikebaily
Hello,
This site seems to be a wealth of knowledge. it seems simple enough that it could be the main switch (timer) but I had just finished a load of clothes and started the second when the machine just went dead.
I intend to get a new switch but was wondering if there might be somthing else to cause.
I have checked the electrical connection and all is good there.
The machine is not nearby so if I need to get some aditional parts I feel really good about your return policy
Thank you
#2 Posted : Tuesday, August 10, 2010 4:36:00 PM(UTC)
Quote:
...I had just finished a load of clothes and started the second when the machine just went dead...
Did it happen at the very beginning of the cycle or sometime later?
I'm afraid you would have to go there at least two times. Such washer needs diagnosis, otherwise you have to order too many parts. I'm not even sure which parts to order due to lack of information.
Here is the Tech sheet.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE GLTF1670AS0 Frtld Wshr - Frigidaire Gal | AppliancePartsPros.com
mikebaily
#3 Posted : Tuesday, August 10, 2010 4:40:48 PM(UTC)
mikebaily
Right at the begining, I set the dial like usual but nothing happened when i pulled out the knob
#4 Posted : Tuesday, August 10, 2010 5:05:32 PM(UTC)
Did you try to play with the timer knob?
Sounds like the timer could be the culprit. Make sure there is 120 VAC to the washer. If the voltage is insufficient, it will never work.
- The timer Part number: AP2108034
mikebaily
#5 Posted : Tuesday, August 10, 2010 5:10:40 PM(UTC)
mikebaily
I have a timer, door switch comming.
thank you for the reply
#6 Posted : Tuesday, August 10, 2010 5:13:47 PM(UTC)
You are welcome. I do not think the door switch can be involved in this problem. Keep us posted.
mikebaily
#7 Posted : Tuesday, August 10, 2010 5:20:23 PM(UTC)
mikebaily
do you have any quick tips on replaceing the timer. I read one post that mentioned using a srewdriver to remove a rod of somesort to get the this off
#8 Posted : Tuesday, August 10, 2010 5:33:17 PM(UTC)
There is nothing complicated about it. Remove the top panel and you will see what to do next.
mikebaily
#9 Posted : Monday, August 16, 2010 6:51:25 PM(UTC)
mikebaily
Well i felt like a real newbie when we found out that the GFI circut was faulty.
Replaced the outlet and the thing worked.
I must have ben asked a half a dozen times if there was power to the washer, and there was sometimes.
Electricity is a funny thing somtimes.
I love the return policy
Great site, i will use it again
quiddaoens2001
#10 Posted : Thursday, August 19, 2010 4:19:11 PM(UTC)
quiddaoens2001
Check the timer switch connection by shaking the plug connector, i had the same problem and got it fixed. Well known problem for this model.
remove top lid to access the timer and follow the black and white wire connection to timer, that's the plug you need to check and jiggle a little.
Guest (7)
