spreston
#1 Posted : Tuesday, August 10, 2010 4:20:24 PM(UTC)
spreston
My dryer won't turn on. My husband checked the thermal fuse and it is good. The timer is running and the door latch is good. What else would cause it not to turn on at ALL! Please help.
#2 Posted : Wednesday, August 11, 2010 2:26:49 AM(UTC)
Replacement parts for WHIRLPOOL KEYE670BWH2 | AppliancePartsPros.com
And a wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203401724.pdf
I am assuming that the thermal fuse and the door switch were checked with a meter and that one side of the device being measured was disconnected to prevent reading an alternate/parallel circuit path. Also that the motor does not make any noise when you try to start the unit.
Items left in the start up circuit are:
1. Push-To-Start relay contacts
2. Timer Switch 4 (T/W contacts)
3. Timer contacts BK/BU
4. The motor or it's centrifugal switch.
spreston
#3 Posted : Wednesday, August 11, 2010 2:30:52 AM(UTC)
spreston
We figured it out it is the relay (start Button). Thanks for your reply.:)
Dryer won't turn on (Dryer Repair)
by spreston 8/10/2010 4:24:24 PM(UTC)
