stevenr10
#1 Posted : Tuesday, August 10, 2010 9:42:25 AM(UTC)
stevenr10
Dryer works good but I have to keep checking the cloths, will not run through cycle timmer just stays in its place that I set it on..:confused:
#2 Posted : Tuesday, August 10, 2010 12:35:06 PM(UTC)
Open the control panel and check the timer motor for continuity. Check for 120 VAC to the timer motor while the dryer is on. Post the results.
- The timer Part number: AP3995012
stevenr10
#3 Posted : Tuesday, August 10, 2010 12:49:07 PM(UTC)
stevenr10
ok will do ! I'll get a tester from a friend tomorrow and let you know what the results are ... Thank you very much
