AppliancePartsPros.com
Appliance Repair Help
Washer Repair
will spin but not at high speed to extract water
it will spin but not fast to extract water from clothes what can i do please help :confused:
Originally Posted by: tileman  it will spin but not fast to extract water from clothes what can i do please help :confused: First, Check and make sure there are no small articles stuck between the tubs causing a drag and slow spin. Is the drain water out of the tub in 90 seconds or less? Clogged malfunctioning drain pump or kinked hose. Is there any new, abnormal noises when the unit is in spin ? I suspect you have a brake / clutch assembly problem,in the drive train, But do these checks first.
is this something i can fix myself and how much are the parts?
Originally Posted by: tileman  is this something i can fix myself and how much are the parts? I believe you could fix this yourself. The part you need is relatively inexpensive. (see attached / click on part number) Part number: AP3094537
how do i get the motor off the barrell
To get the motor off the tranny side, remove the screws holding the clips in place, then pry off the clips.
Originally Posted by: richappy  To get the motor off the tranny side, remove the screws holding the clips in place, then pry off the clips. ok i got the motor off how do i get the tranny off to get to the clutch thanks for all the help
Remove the agitator and the three tranny bolts and pull out the tranny.
ok i put the new clutch in and it worked for a minute and now it is still doing the same thing what could be the problem?:eek:
Did you read my sticky that Joe suggested??
Washer Repair
