Dryer works good but I have to keep checking the cloths, will not run through cycle timmer just stays in its place that I set it on..:confused:
Open the control panel and check the timer motor for continuity. Check for 120 VAC to the timer motor while the dryer is on. Post the results. - The timer Part number: AP3995012
ok will do ! I'll get a tester from a friend tomorrow and let you know what the results are ... Thank you very much
