Iliff107
#1 Posted : Monday, August 9, 2010 9:40:43 AM(UTC)
Iliff107
The dryer operates fine, however the dryer sheets always end up in the lint collector screen. This happens in all modes including no heat.
Joe / APP Team
#2 Posted : Monday, August 9, 2010 10:25:27 AM(UTC)
Joe / APP Team
Check and make sure that the filter is dropping all the way down and into the guide.
Remove the filter and using the crevice tool on your vaccuum cleaner, remove all the lint in the housing, check the guide tracks for clogs and debris and remove (i used a long thin blade screw driver).
I'm sure you'll find something there, I used to quite often.
