Here are your parts includes a wiring diagram
Replacement parts for ADMIRAL ADE20N3V Dryer - Ele | AppliancePartsPros.comSounds like your heating element may have blown.
Could be it was grounded and is now blown.
On this unit if the heater blows or shorts to ground the timer will not advance in auto modes as it gets power through the heater element when the element is off. In timed dry mode the timer gets power directly from the line,
Try running the unit in timed dry and auto modes.
If the timer advances in timed dry but not auto, odds are either the heater or the heater's safety thermostat (fuse) is blown.
Also check that the unit is getting 240.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
The Safety Thermostat (Item 5 in Section 4) is near the heating element
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I beleive richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
