rh233
#1 Posted : Wednesday, August 4, 2010 7:52:27 PM(UTC)
rh233
My 4 yr old roper dryer takes almost double the amount of time to dry now. My maintenance man looked at it for me (used his tester) and told me that it needs a new timer. Is there a chance that he could be wrong then I would have to invest more money into another part. Any thoughts? Thanks (Serial #mu1057074)
#2 Posted : Saturday, August 7, 2010 3:43:28 AM(UTC)
Replacement parts for WHIRLPOOL RED4440SQ0 29"electric Dryer | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528190.pdf
I am assuming this also happens when you run the unit in timed dry mode.
The most common cause of this is a dirty/malfunctioning vent system.
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems
