glassmigrations
#1 Posted : Friday, July 30, 2010 1:43:42 PM(UTC)
glassmigrations
The hard encasement panel that holds the drum sliders in place and serves as a cover for the lamp's electrical wires broke(upper semi circular protective panel). This is located inside the upper portion of my dryer door on my front load dryer(DBVH512EFWW). I need to replace the top plate but I cannot find the part number or a picture of it anywhere in the schematics. I am also having to replace the drum sliders and not too sure about the felt ring. Does anyone know what this hard semi circular plate is called/part #? Can you direct me on everthing I need buy to replace the drum sliders? Any help will be greatly appreciated. Also the number embossed inside the broken panel is #2 212D1107, just in case this may provide any help determining exactly what part this is.
ThatGuy
#2 Posted : Saturday, July 31, 2010 5:43:25 AM(UTC)
ThatGuy
Groups: Expert
United States
Check out this page. Front panel replacement parts for General Electric DBVH512EF0WW Electric dryer | AppliancePartsPros.com
I think the parts you are talking about are 312, 313, 315, and 316.
glassmigrations
#3 Posted : Wednesday, August 4, 2010 2:04:31 PM(UTC)
glassmigrations
I appreciate your help and did confirm the parts you had listed against the ones I thought might be the ones I needed. Wish me luck on the repair. :confused:
ThatGuy
#4 Posted : Wednesday, August 4, 2010 2:43:03 PM(UTC)
ThatGuy
Groups: Expert
United States
Good luck! But you won't need it. Its pretty straight forward. You'll be done in no time.
