hitekpolo
#1 Posted : Wednesday, August 4, 2010 1:46:35 AM(UTC)
hitekpolo
The light is on so the unit is getting power but it will not start. No sound is made when you try to start it, nothing happens. Please help.
jimmyds
#2 Posted : Wednesday, August 11, 2010 7:24:57 AM(UTC)
jimmyds
Usually your problem is (in this order):
1. House breaker or faulty plug wire connection at the wall or on the block in the dryer.
2.Dryer fuse inside back panel near motor on blower chute.Resister MUST have full continuity.It's usually 1/4 wide and 1 1/2 in long and is white plastic with black middle.It blows when you have to much lent in the filter causing overheating of the exiting air.
3.Your door switch is no good.
4.Starter windings in motor are burned out.;) Jimmyds.
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
