2 Pages12>
tileman
#1 Posted : Tuesday, August 3, 2010 7:52:03 AM(UTC)
tileman
it will spin but not fast to extract water from clothes what can i do please help :confused:
Joe / APP Team
#2 Posted : Tuesday, August 3, 2010 8:48:11 AM(UTC)
Joe / APP Team
First,
Check and make sure there are no small articles stuck between the tubs causing a drag and slow spin.
Is the drain water out of the tub in 90 seconds or less?
Clogged malfunctioning drain pump or kinked hose.
Is there any new, abnormal noises when the unit is in spin ?
I suspect you have a brake / clutch assembly problem,in the drive train,
But do these checks first.
tileman
#3 Posted : Tuesday, August 3, 2010 11:15:25 AM(UTC)
tileman
is this something i can fix myself and how much are the parts?
Joe / APP Team
#4 Posted : Tuesday, August 3, 2010 11:49:01 AM(UTC)
Joe / APP Team
I believe you could fix this yourself.
The part you need is relatively inexpensive.
(see attached / click on part number)
Part number: AP3094537
I have also attached a pretty comprehensive test and repair procedure, prepared by one of my colleagues, for a better understanding for you.
I'm sure you could do it,
http://forum.appliancepartspros...direct+drive+brake+shoes
I hope this all helps you,
Good Luck
tileman
#5 Posted : Thursday, August 5, 2010 3:04:49 PM(UTC)
tileman
how do i get the motor off the barrell
#6 Posted : Friday, August 6, 2010 3:18:30 AM(UTC)
To get the motor off the tranny side, remove the screws holding the clips in place, then pry off the clips.
tileman
#7 Posted : Friday, August 6, 2010 12:57:15 PM(UTC)
tileman
ok i got the motor off how do i get the tranny off to get to the clutch thanks for all the help
#8 Posted : Saturday, August 7, 2010 1:06:28 AM(UTC)
Remove the agitator and the three tranny bolts and pull out the tranny.
tileman
#9 Posted : Tuesday, August 10, 2010 12:31:50 PM(UTC)
tileman
ok i put the new clutch in and it worked for a minute and now it is still doing the same thing what could be the problem?:eek:
#10 Posted : Tuesday, August 10, 2010 3:52:00 PM(UTC)
Did you read my sticky that Joe suggested??
2 Pages12>
