awthorp
#1 Posted : Tuesday, August 3, 2010 8:00:04 AM(UTC)
awthorp
Maytag LDG7500ABW Gas dryer.
The igniter will light some times there is a blue flame but never lasts for full dry cycle, can hear a buzzing clicking sound when igniter is glowing but no flame. Any thoughts?
Joe / APP Team
#2 Posted : Tuesday, August 3, 2010 8:36:40 AM(UTC)
Joe / APP Team
Does the igniter continue to cycle off and on, even though there is no flame ?
The buzzing ,clicking noise and no flame would lead me to believe you have a bad solenoid / coil on your gas valve,if your igniter is cycling.
(click on part number for description)
Part number: AP3041625
Part number: AP3041626
Part number: AP3094251
I personally preferred to replace the coil kit, versus individual parts.
It's a quick,easy, relatively in expensive, repair.
If you prefer , I can give you coil resistances so you can test and order the individual parts.
awthorp
#3 Posted : Tuesday, August 3, 2010 9:20:39 AM(UTC)
awthorp
As far as I can tell when the ignighter lights it would stay on as if it was lighting flame, the odd time the flame lights but will not stay on for full cycle
Joe / APP Team
#4 Posted : Tuesday, August 3, 2010 10:49:35 AM(UTC)
Joe / APP Team
Correct,
Here is the basic operation of a gas valve ignition system:
When you select a heat cycle and the thermostats are cool, power is applied to coils, goes through the coils and to the igniter.
The igniter glows until it reaches approximately 2000 degrees(almost white hot). The radiant sensor opens and the circuit back to the coils,is completed and the coils energize and release the gas, the gas ignites.
The process repeats,until the clothes are dry.
If you have weak or inoperative coils, no gas will be released, and no flame,but the process will continue until the unit stops or is stopped.
The clicking and other noises, is usually the coil attempting to lift the plunger in the gas valve. it cannot because the coil wiring is weak and separating, eventually causing no draw at all on the plunger and no flame from the burner assembly.
You can check the resistance of the coils with a multi meter, but if they are cool(not having cycled a few times)you will get a false reading.
Here are the resistance readings for the coils :
The 2 terminal coil should read 1000 to 1500 ohms.
The 3 terminal coil should read 1300 to 1400 ohms from pin 1 to pin 2.
The 3 terminal coil should read 500 to 600 ohms from pin 1 to pin 3.
The resistance should remain relatively the same wether the coil is cool or "hot" from operation.
I hope this is a better explanation and is more assistance for you.
No flame LG dlg2532w (Dryer Repair)
by Rick Sutton 3/5/2022 5:40:18 PM(UTC)
Ignitor sparks and gas is flowing but no flame (Oven Repair (including Ranges and Cooktops))
by jimb39 11/18/2018 1:01:33 PM(UTC)
Dryer Ignitor Glows but no Flames (Dryer Repair)
by ken1234ken 7/9/2016 12:05:48 PM(UTC)
GE Gas Dryer Igniter Glows but No Flame (Dryer Repair)
by kwillindy 5/4/2015 9:21:49 AM(UTC)
Igniter Glows, No Flame - replaced gas coil and thermal cuttoff (Dryer Repair)
by knnguyen86 10/24/2014 9:46:08 PM(UTC)
Dryer has no flame (or heat) (Dryer Repair)
by MrChip 1/14/2014 12:22:21 PM(UTC)
no flame (Dryer Repair)
by dong 7/30/2013 12:31:34 AM(UTC)
Kenmore Dryer - Ignitor glows for 10 seconds no flame (Dryer Repair)
by jwmark 12/12/2012 7:59:10 PM(UTC)
Kenmore Dryer starts. No Ignitor, No flame no heat (Dryer Repair)
by jmrec100 12/11/2012 9:14:50 PM(UTC)
by joe5427 9/17/2012 4:25:49 PM(UTC)
Whirlpool heats for a minute and then no flame (Dryer Repair)
by karolpl2004 7/13/2012 12:51:48 PM(UTC)
Gas Dryer no flame (Dryer Repair)
by Emazing 6/6/2012 1:57:26 PM(UTC)
gas dryer no flame (Dryer Repair)
by stargate1 6/12/2011 11:47:06 AM(UTC)
Igniter lights but no flame (Dryer Repair)
by recap 6/3/2011 2:40:19 PM(UTC)
Magic Chef oven does not turn on - no flame (Oven Repair (including Ranges and Cooktops))
by teapa 5/20/2011 7:42:07 AM(UTC)
