bigmatt
#1 Posted : Thursday, July 29, 2010 5:04:01 AM(UTC)
bigmatt
hi.. i have a question.my gas dryer when turned on,the igniter will glow and kick on the gas for about 45 seconds and then shut off the flames.it might glow one more time,and then the igniter will not glow and no gas after that.i put a new igniter in,but still does the same thing.ant help appreciated.
matt
Joe / APP Team
#2 Posted : Thursday, July 29, 2010 6:46:11 AM(UTC)
Joe / APP Team
matt
Matt,
Did this occur suddenly, or was it a gradual process ?
At this point I would suspect, an open radiant sensor,or coil on the gas valve.
I don't think, you've got a thermostat, thermal fuse or control problem,
Do you have a multi meter to test circuits ?
We will be glad to assist you.
bigmatt
#3 Posted : Thursday, July 29, 2010 6:52:16 AM(UTC)
bigmatt
thanks for the response...it did it suddenly...i don't have a multitester.i was thinking maybe a coil,i'm not sure i know what and where the radiant sensor is.thanks for any help.
matt
Joe / APP Team
#4 Posted : Thursday, July 29, 2010 7:58:37 AM(UTC)
Joe / APP Team
matt
Matt,
The radiant sensor is located on the side of the burner inlet tube. It looks like a black box,and has two wires(usually black and white)there is also a rectangular cut out in the burner inlet tube,if that helps you.
The gas valve coils, are the black cylinders attached to the top of the gas valve itself.
Without a meter it will be hard to diagnose, and can only be a guess.
If this occurred suddenly,there maybe other components involved, and I am starting to wonder.
Valve coils usually can make a buzzing noise when they weaken or fail,
and usually you notice the dryer begins taking longer to dry.
I don't know where you want to start, but this would be a good spot, without a meter.
I hope this helps you.
bigmatt
#5 Posted : Thursday, July 29, 2010 8:52:01 AM(UTC)
bigmatt
i am going to go buy a tester..where should i start checking things...thanks
matt
Joe / APP Team
#6 Posted : Thursday, July 29, 2010 12:18:38 PM(UTC)
Joe / APP Team
matt
Matt,
Good idea, the meter , it will come in handy in the long run.
I have attached a really nice link, it's an information sheet on how a multimeter operates and how to use it.(you may even get the same information with a new meter).
http://forum.appliancepartspros...ghlight=testing+circuits
Both of the components you are going to check are in basically the same area(as I described before)
The radiant sensor is a closed circuit when cool and opens at approximately 1800 to 2000 degrees.
The coils have a consistant resistance if they're good.
The 2 terminal coil should have 1200 ohms resistance, when meter probes are across both terminals.(no wires attached, or at least one removed.)
The 3 terminal coils (numberred 1,2,3, from left to right looking at the terminals should check as follows:
pin 1 to pin 2 should have 1350 ohms
pin 1 to pin 3 should have 550 ohms
allow 10% resistance + or- resistance would still be an allowable range.
Hope to hear you've got it repaired soon
bigmatt
#7 Posted : Friday, July 30, 2010 4:13:24 AM(UTC)
bigmatt
thanks a lot for your help i really appreciate it
