worked fine lastnight, will not start now. replaced timer several months ago, have checked breaker and have power up to timer and start switch
Groups: Expert
Originally Posted by: Amy Dolsen  worked fine lastnight, will not start now. replaced timer several months ago, have checked breaker and have power up to timer and start switch Check the door switch and see if its clicking and if it has continuity.
I would go with door switch also.
replaced door switch today as well as push start button and still no go already replaced timer not to long ago.
Does it have 220/240volts at wall plug??
Originally Posted by: Amy Dolsen  worked fine lastnight, will not start now. replaced timer several months ago, have checked breaker and have power up to timer and start switch Remove the rear panel and check the thermal fuse (#23 on the diagram) for continuity. - The thermal fuse Part number: AP3132867
