pleasantlake
#1 Posted : Monday, July 26, 2010 9:21:13 AM(UTC)
pleasantlake
Machine filled with water and shut down. 20 years old. Water still in tub, could this be timer motor or timer?
Joe / APP Team
#2 Posted : Monday, July 26, 2010 10:33:51 AM(UTC)
Joe / APP Team
Did you try to drain the water using the spin/ drain cycle ?
Raise and lower the loading lid, do you hear a click from the lid switch assembly? A bad lid switch would keep the motor & timer from running(the most common problem).
If it should test out and be a timer problem, You will need a timer complete, due to probable contact damage in the timer itself.
Part number: AP4024441
Kenmore Cloths Washer (Washer Repair)
by Paul S Andrus 2/6/2013 10:51:20 AM(UTC)
Whirlpool cloths washer F-24 (Washer Repair)
by plecoman 4/6/2011 4:28:15 AM(UTC)
cloths washer not working (Washer Repair)
by bjhamrick 5/25/2010 8:48:57 AM(UTC)
Cloths washer rotory switch (Washer Repair)
by Martn Mieger 9/22/2009 10:03:33 AM(UTC)
