lizpet35
#1 Posted : Monday, July 26, 2010 7:37:06 AM(UTC)
lizpet35
The iginiter glows red but the gas does not fire up. The dryer continues to spin and the iginiter comes on repeatedly every few minutes. Pls help.
Joe / APP Team
#2 Posted : Monday, July 26, 2010 8:06:42 AM(UTC)
Joe / APP Team
Your description leads me to believe , you have a failed gas valve solenoid(coil) on you gas valve.
Are you sure the gas has not been turned off to the the dryer?
Please varify your description: igniter glows red and goes out in a few seconds but no gas is released.
If this is all correct, I suggest you start at replacing the coil kit on the gas valve.
Pleas see attached part number and picture.
Good luck,
Part number: AP3094251
aircargoo
#3 Posted : Monday, July 26, 2010 3:37:28 PM(UTC)
aircargoo
i ordered EXACT part today.......$23,,,,not bad with shipping.
mine did samething....i saw glow...so that parts good. i ordered coils............lets c.;)
Joe / APP Team
#4 Posted : Tuesday, July 27, 2010 6:00:10 AM(UTC)
Joe / APP Team
You're welcome,
happy laundering.
cb3
#5 Posted : Wednesday, July 28, 2010 10:52:03 AM(UTC)
cb3
I had the same problem. I checked my coils for continuity and got nothing. I ordered the coils and I'm not getting continuity on the new ones right out of the box. Shouldn't I be getting continuity on these new ones?
Joe / APP Team
#6 Posted : Wednesday, July 28, 2010 11:08:51 AM(UTC)
Joe / APP Team
Yes you should be able to read resistance across the coils.
Is your meter set to the correct ohms resistance range ?
The 2 terminal coil should read apprximately 1000 ohms.
the 3 terminal coil should read approximately 500 ohms across the 2 outside terminals, an 1300 ohms across the middle terminal and the pin to left side (term. #1)of the dual coil solenoid terminals.
cb3
#7 Posted : Wednesday, July 28, 2010 11:17:56 AM(UTC)
cb3
It was an audible meter. Touching the leads together produced a loud beep but touching the coil terminals produced nothing. I should return these?
Joe / APP Team
#8 Posted : Wednesday, July 28, 2010 11:29:56 AM(UTC)
Joe / APP Team
Do you know the RX scale of the meter ?
I prefer an anolog meter or adjustable digital meter, not one that beeps only or an auto ranger meter.
A bad part out of the box is a possibility. You may want to return them and try again, but if you get the same resistance, try another meter on the correct settings.
