Hi, I have some water accumulating under the deli basket in the refrigerator side of my side by side GE profile refrigerator. I cannot seem to find the soirce of water.
Any help is much appreciated.
Thanks!
You might have a leak in the water reservoir in back of the crisper drawer.
Originally Posted by: richappy  You might have a leak in the water reservoir in back of the crisper drawer. Thanks Rich, thats what it turned out to be...:) Any tips on how to replace the tank assembly? I just ordered the same from here. Thanks again!
Originally Posted by: bhavinjo  Hi, I have some water accumulating under the deli basket in the refrigerator side of my side by side GE profile refrigerator. I cannot seem to find the soirce of water.
Thanks! Is there water or ice on the freezer floor as well? Did someone spill water or soda in the compartment? If not, I reccomend you check and insure there are no articles touching the walls(back or side walls) of the fresh food compartment. Check the control on the bin, 1/2 to 2/3 open is usually the reccomended settings, and no paper products in the bin bottom to absorb water. Check the door gasket( lower portion most likely)of the fresh food door gasket for a proper seal to the front of the compartment. and clean the condenser coils thoroughly for proper operation of the unit. you should be able to find the problem with these quick,easy checks.
The new resevoir comes with all the couplers needed.
