GE
bbarker
#1 Posted : Monday, July 19, 2010 7:27:09 PM(UTC)
bbarker
I have a GE refrigerator that the refrigerator and freezer will not keep a constant temperature.
The freezer temperature will increase to 7 degrees and the refrigerator will increase to 45 degrees (set at 0 and 37).
After awhile, the temperature will drop to 0 and 37 degrees.
Any idea what the problem maybe?
thanks
#2 Posted : Tuesday, July 20, 2010 1:49:28 AM(UTC)
When the temperatures start to rise, tell us what is running/not running.
RICKEY S WORLEY
#3 Posted : Tuesday, July 20, 2010 9:44:12 AM(UTC)
RICKEY S WORLEY
Fridge Is Cold In The Bottom But Not In Top. Ice Maker In Freezer Quiet When This Started
#4 Posted : Tuesday, July 20, 2010 12:49:00 PM(UTC)
Would like to suggest, you start your own thread in the Refrigerator Repair section, using Post New Topic.
People will then see it is someone with a problem.
This should increase your odds of getting a relevant reply.
Do not forget to post the complete model number of the refrigerator and as much as possible problem description.
old kenmore fridge click (Refrigerator & Freezer Repair)
by rleescott 7/4/2024 7:07:45 AM(UTC)
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
Replacing oven bake burner on GE JCB920BEC4BB (Oven Repair (including Ranges and Cooktops))
by Guest 6/30/2024 7:37:19 AM(UTC)
OLD FRIDGEDAIRE OVER & UNDER GLRT214RAW4 (Refrigerator & Freezer Repair)
by brou102 6/29/2024 10:51:20 AM(UTC)
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 6/28/2024 8:33:23 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
LG Fridge - Air condensing at back of freezer (Refrigerator & Freezer Repair)
by Guest 6/25/2024 5:44:16 AM(UTC)
Kenmore Fridge Supco (Refrigerator & Freezer Repair)
by Tony442 6/23/2024 8:34:01 PM(UTC)
GE Profile Oven heating very slowly (Oven Repair (including Ranges and Cooktops))
by Reddogmatic 6/23/2024 4:53:08 PM(UTC)
True GDM-26-LD Display Fridge compressor issues (Refrigerator & Freezer Repair)
by KSlank76 6/22/2024 10:24:23 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
WRF989SDAM03 Whirlpool fridge making ice very slowly (Refrigerator & Freezer Repair)
by BlueWRXPride 6/20/2024 5:24:45 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
