Bob551
#1 Posted : Monday, July 19, 2010 9:45:26 PM(UTC)
Bob551
Gene,
I've read through the posts of dryer problems. My problem is that heat quit working. I have power to the gas and ignition system, ignitor comes on but no sound from gas valve or gas flow. I've checked coil resistance, coil with 2 terminals is ok, but on coil with three terminals ohm readings are high by 600 and 800 ohms respectively. For several months the dryer has made a loud buzzing noise upon igniting, than ran ok. Sounds like the coil, but usually they fail open instead of having out of range ohm readings. I'm hoping it's the coil, because the valve is about $200. What's your thought?
Joe / APP Team
#2 Posted : Tuesday, July 20, 2010 1:21:45 PM(UTC)
Joe / APP Team
Originally Posted by: Bob551 Go to Quoted Post
Gene,
I have to agree with you based in the information you supplied.
I would replace the coils as an assembly(both coils)
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
