William Gravett
#1 Posted : Friday, June 25, 2010 5:04:52 PM(UTC)
William Gravett
The blown device is located on the air chute and close to the hot air outlet. I replaced it and the device close to the bottom of the chute once back in April. Worked fine for a bout 6 weeks then the device at the top blew again.
The resistance across the heater element is 10.8 ohms....in spec. As far as I can tell the exhaust line is clear.
Was thinking that after multiple drying sessions at high heat setting, maybe allowing system to cool for say a half hour or so before starting up another load would help the problem. Any help would be appreciated.
Thanks:confused:
