The exterior sides on my upright freezer are very warm but freezer temperature is ok. I suspect the condensor fan is not working but I have not been able to locate a diagram as to where it is located. Could anything else cause the exterior sides to be hot? If the condensor fan is out will cause any damage in the short term i.e. a couple of days?
Thanks,
Mark
