My freezer's ice maker won't produce ice anymore. I tried removing the water filter to see if that was the problem, but no luck. I can see the ice makers parts moving so it has power. The fridge comes with a ice chute and water dispenser on the front, and the water dispenser has water so I think the water supply line is ok too. Here's the link to the manual: http://manuals.frigidaire.com/p...Anderson/240581300en.pdfI'm open for any ideas. Thanks!!!!
Groups: Expert
change your water valve(s), usually one assembly, sometimes two. its best to change them all.
