lrlarsen17
#1 Posted : Wednesday, March 31, 2010 11:48:39 AM(UTC)
lrlarsen17
frige is warm. Freezer is fine. The refigerator is making normal cooling sounds. A couple of years ago while under warrenty it had the same problem.
lrlarsen17
#2 Posted : Wednesday, March 31, 2010 2:10:18 PM(UTC)
lrlarsen17
took back panel off and cleaned everything..... refrigerator works
FridgeDoctor
#3 Posted : Wednesday, March 31, 2010 2:16:24 PM(UTC)
FridgeDoctor
Groups: Expert
sounds like a defrost problem, thick frost on back freezer wall? problem with either your defrost control, defrost heater element, or the defrost bi metal thermostat.
