Washer not draining. Burning smell
Good news: I got the new motor, installed it and the macine runs through a cycle now.
Bad news: It’s not draining. It gets to the end of a cycle and the washer is still full. If I then activate “extra rinse”, the water will drain. From what I can tell from the service manual, if the drain at the end of “extra rinse” is working, then the problem’s not with the pump. So what else could it be?
Also, since I can ensure that the water drains by activating the extra rinse, I can catch up on my laundry backlog now, but I’m worried that the problem I’m seeing now may have been there originally and is what caused my motor to die. Am I just being paranoid or is this a real possibility?
