Okay, I took the front panel off, leaned the machine back a bit so I could reach under and move the belt and pulleys.
The pump spun freely in both directions. The transmission spun freely in both directions. The motor pulley spun freely in both directions.
Given that everything was spinning okay, I didn’t remove the belt, but I did start the machine in the spin cycle. There was the same humming noise I heard before, followed by a steady stream of smoke coming from the top of the motor.
Can’t get much more “smoking gun” than that ![]()
The repair manual talks about a “motor switch”, as well as the motor itself, but the online parts diagram makes it look like it’s all one unit. Is the motor switch a separately replaceable part and, if so, could it be the cause of the problem (like if it were never releasing the “start” winding)? Otherwise, I guess that I just need to replace the “motor assembly”, right?
