biggjon1
#1 Posted : Wednesday, February 10, 2010 3:52:31 PM(UTC)
biggjon1
My Maytag stopped cooling. I took the rear cover off and unplugged the fridge. I waited 10 min and plugged it back in. I heard a clicking noise but was not sure if it was the capacitor of the overload relay. I tapped on both and the compressor started. What should I replace? Also when I looked up the model number it comes up with 2 different models.They are PTB1753GRQ and PTB1753GRW....what is the difference between the two?
#2 Posted : Thursday, February 11, 2010 3:48:47 AM(UTC)
Here are the parts
Replacement parts for PTB1753GR models | AppliancePartsPros.com
[COLOR="Blue"]My Maytag stopped cooling. I took the rear cover off and unplugged the fridge. I waited 10 min and plugged it back in. I heard a clicking noise but was not sure if it was the capacitor of the overload relay. I tapped on both and the compressor started. What should I replace? [/COLOR]
Clicking will not be in the capacitor so probably it is the overload/relay especially since it has been re-designed.
Here is a good link on how to check things
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
[COLOR="Blue"]Also when I looked up the model number it comes up with 2 different models.They are PTB1753GRQ and PTB1753GRW....what is the difference between the two?[/COLOR]
Do not know but in this case it does not matter as both units use the same compressor etc.
maytag fridge not cooling but freezer is fine (Refrigerator & Freezer Repair)
by jdubstewart 1/5/2014 6:23:09 PM(UTC)
Maytag Fridge not cooling no air (Refrigerator & Freezer Repair)
by AndrewMS 7/21/2011 7:12:16 PM(UTC)
maytag fridge not cooling (Refrigerator & Freezer Repair)
by eazzrider 9/10/2009 1:40:10 PM(UTC)
