Maytag washing machine drum does not spin
OK, I got the agitator and the inner drum off. Without those parts, it works fine !! All I can see in there now is excessive hardwater buildup deposits. Chunks maybe 1/8" or greater in thickness. Is it possible that those deposits, floating loose in between the inner and outer drum could have jammed it up and prevented it from spinning ?? I hope so…
