I’ll give you the best play by play I can from memory (you’re in trouble).
The top cap of the agitator can be pried off to expose the nut that holds the agitator in place (1/2in) I think. Loosen bolt and pull. It may take some effort they get stuck sometimes. Remove the Two phillip head screws at the bottom front to remove front panel. Remove the 3/8in bolts (2) 1 in each top front corner and remove bleach hose from top. Pivot top back out of your way. Remove tub ring. Remove bell (metal dome) to expose tub nut. Once you get that off the inner tub is free. It’s rarely easy. Oh yeah, I almost forgot (you would have hated me) the tub nut is a reverse thread!
