GabrielS
#1 Posted : Monday, January 25, 2010 6:38:40 AM(UTC)
GabrielS
Hi all. I am in big troubles. My Mytag LSG7806AAM washer appliance doesn't work fine. Everything's Ok. Timer starts, filling valves OK, pressure switch is Ok at different levels, but when filling cycle is OK, washing cycle doesn't start. Motor is OK (Run and start windings), capacitor is OK, fuses are Ok, Overload Protector is closed, but motor doesn't Run .... I don't know what more to check. I am needing the Timer Cycles Diagram (Switching intervals) to check it. Where could I fin it?
Any help is very very appreciated.
sidfink43
#2 Posted : Monday, January 25, 2010 5:26:00 PM(UTC)
sidfink43
I do not have access to any service technical info on this model. You can check inside the console to see if there is a wiring diagram with tech notes.
You can also
1. Check the lid switch
2. Check the wiring from the timer to the motor
3. Take off the connectors at both the motor and timer and clean them with contact cleaner and reseat
