Have a front load machine, it will go through all the cycles, but on the spin cycle it never reaches high speed. It will spin, but it is slow speed. The pump is clean, the belt seems tight. It seems like a senser or a control board?
thanks -Lee
Look inside the lower service panel and see if there is a set of tech notes that will allow you to put it into diagnosis/troubleshooting mode.
I would think that your motor/speed control board is the problem but try to verify that with testing.
I am also having trouble getting your model number to come up, if you need more assistance please check it and post the correct one, along with the results of your testing.
LTF29400EE0 comes up as a Frigidair Washer on this site. I have not been able to locate a manual to check the test cycle. thank -Lee
yea 90% the motor control board is the problem. The board is located on the bottom right side of the tub, with the back panel off. But you can test with meter as Sid suggested. But all i have seen, it is the motor control board.
Turn the spin basket and see if it turns "rough", this would indicate bad tub bearings, a common reason for speed control board failures, I believe any current draw above 3 amps will damage the board.
