shu7241
#1 Posted : Monday, January 4, 2010 11:21:56 AM(UTC)
shu7241
Clothes are still very wet when coming out of washer. There is no water in the bottom of tub. I checked pump and hoses and all seem OK. The washer seems to agitate OK but won't spin fast enough to get water out of clothes. The clothes aren't plastered against the side of the tub after spinning. I have a sears diagram and am fairly handy but have no experience with washers. I don't believe there is anything between tub and liner. Also can you tell me how to get the top to raise up. Thanks for any help. Bill
sidfink43
#2 Posted : Wednesday, January 6, 2010 12:52:40 PM(UTC)
sidfink43
Take off the cabinet and check the pump and hoses thoroughly. If you clothes are too wet either the drain is blocked, the pump is not working correctly or the spinning is too slow. If the spinning is too slow the clutch is a likely problem.
This site will show you how to take off the cabinet, and if you decide to replace the clutch it will show you how to do that also.
Clutch Replacement on Whirlpool and Kenmore Washers[URL="http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=110.26882501"][/URL]
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Whirlpool cabrio washer codes (Washer Repair)
by Guest 4/20/2024 11:59:12 AM(UTC)
LG washer not letting in cold water (Washer Repair)
by Cgrigson1 4/19/2024 7:34:57 AM(UTC)
Samsung top load washer won’t start (Washer Repair)
by aw2055989 4/19/2024 4:42:33 AM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag LA882 Washer (Dishwasher Repair)
by soloRepairer 3/30/2024 2:12:38 PM(UTC)
Maytag centennial washer- motor won’t spin (Washer Repair)
by Guest 3/30/2024 1:59:24 PM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Replacing a stacking Bosch Axxis+ Washer (Washer Repair)
by DonLafontaine 3/22/2024 3:59:06 AM(UTC)
Kenmore series 90 washer stopped working (Washer Repair)
by Guest 3/16/2024 6:19:45 AM(UTC)
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
