AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Noisy squeaking direct drive washer; extra part?
A few weeks ago I replaced the transmission in my washer. Everything has been working great, except today it started squeaking during agitation and the spin cycle. A day or two ago I was straightening up my tools and found this washer. I'm pretty sure it came from my washing machine, but I can't find it on any parts diagram. It seems like the squeaking could be because the washer isn't installed.. Does this look familiar to anyone?
It looks like the cover washer/bearing piece that goes over the retaining ring which helps hold the clutch to the transmission housing. it has a tab which goes into the slot on the retaining ring.
Take out your transmission and see if it does go there, replace things and see if that solves your problem.
Washer Repair
