I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights up again, it shows an error, "E6 F2". If we just wait around, the oven has started working again in about 1-2 weeks without any loss of time on the clock. We have had the panel replaced once, however the problem has continued. Any suggestions?
