JPratt
#1 Posted : Sunday, November 15, 2009 7:40:09 AM(UTC)
JPratt
Oven will not heat. We were getting error codes F02 at random. Recently, during baking the oven temp went up to the max by itself and the door locked. We unlocked by turning off the breaker overnight. We also replaced the control unit. The controls work but the oven will not heat.
#2 Posted : Monday, November 16, 2009 4:34:21 AM(UTC)
Here is your tech sheet
http://www.servicematters.com/d...0Sheet%20-%204453057.pdf
Sounds like the unit had a thermal run away.
Perhaps the thermal fuse is blown.
JPratt
#3 Posted : Tuesday, November 17, 2009 4:58:24 PM(UTC)
JPratt
:) Thank you! You have been very helpful. We are pulling the oven to check the fuse. Hopefully we can order the part and be back in business before Thanksgiving.
JPratt
#4 Posted : Saturday, October 29, 2011 10:44:06 AM(UTC)
JPratt
OK, now we have a new problem. The bake and broil does not heat at all. Elements tested OK. The oven will work on Convection.
#5 Posted : Saturday, October 29, 2011 11:05:40 AM(UTC)
See the attachment for the tech sheet, the old source is no longer available.
Here are our parts
Replacement parts for WHIRLPOOL KDRP407HSS4 RANGE-DUAL FUEL | AppliancePartsPros.com
Looking at the wiring diagram I would say that your control board is shot.
Since the convection works correctly you know that power to the unit and it's temperature control is OK. Also that the thermal fuse is OK so that leaves the board.
Before replacing it I would check that all the wiring to the elements is OK.
File Attachment(s):
KDRP407.pdf (429kb) downloaded 11 time(s).
JPratt
#6 Posted : Saturday, October 29, 2011 11:35:21 AM(UTC)
JPratt
Thanks, we were afraid that I was the control board. This is the second time it has gone bad. The oven is only 5 or 6 years old.
JPratt
#7 Posted : Saturday, October 29, 2011 11:50:51 AM(UTC)
JPratt
The website link to your parts for this Control Panel is broken.
JPratt
#8 Posted : Saturday, October 29, 2011 12:12:54 PM(UTC)
JPratt
I can't find the part for the control board in any of the diagrams. And the links to your parts pages do not work.
#9 Posted : Saturday, October 29, 2011 12:52:45 PM(UTC)
Cannot explain why the link does not work. I just tried it (open in new tab) and it worked for me.
Note: I use Firefox.
Perhaps your net security settings are too high.
You could go to the AppliancePartspros parts website and just enter in your model number.
KitchenAid oven will not heat up... replace thermostat? (Oven Repair (including Ranges and Cooktops))
by Matt M 12/7/2010 11:42:49 AM(UTC)
My KitchenAid oven will not heat after cleaning (Oven Repair (including Ranges and Cooktops))
by Dshambo 11/27/2010 4:27:48 AM(UTC)
