LOVE MY MAYTAG IT STARTS TO DRAG WHEN AGITATE THEN SOMETHING SMOKING . HAVE NEW MOTOR , SWITCH OK , NEW BELTS , IS IT TRANMISSION OR SOMETHING TO DO WITH AGITATOR:confused:
Hopefully the problem is something jamming or obstructing the pump, so I would remove the pump and see if it turns freely. If there is a problem, replace or clean it out and you should be fine. Here is the service manual for your machine, and getting to the pump is not difficult. http://www.servicematters.com/m...6010373%20(16001145).pdfIf it is not the pump then am afraid the other possibilities, including the transmission are such that you will want to replace the machine rather than try to fix it. Good luck.
