jklovell
#1 Posted : Monday, November 9, 2009 7:56:33 PM(UTC)
jklovell
Dishwasher quit working abruptly and clean light flashes - no other response. A new control panel was put in, and it worked for about a week, but then it quit and the clean light flashes again. It flashes 7 times, then pauses for about 5 seconds, then repeats (I suppose that this pattern of 7 flashes could be a code).
It did not help to unplug it, then plug it in again. It did not help to replace the new part with the old again - the old did not work the second time it was put in, and the new part also did not work after it was again put back in.
#2 Posted : Tuesday, November 10, 2009 2:03:52 AM(UTC)
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208572216.pdf
Try running the diagnostics to see if it will clear.
Next, I would check out the door switches.
I would then check the heater, the hi-limit thermostat and the thermistor.
Though this is a long shot because I get the impression from you post that it gives the error without running a cycle.
Also it is troubling that the new board ran for a week and then messed up, seems like something else in the machine took the board out so I would check all components with a meter.
jklovell
#3 Posted : Thursday, November 12, 2009 6:44:35 PM(UTC)
jklovell
Thanks for the technical sheet on the Kenmore DW. The DW runs for a few days after by initiating the service diagnostic cycle. But it goes through the diagnostic cycle without a hang up. My questions:
1. Is it right to assume that the problem is intermittent because the DW will go through several cycles before it gets hung up?
2. The sensing light does not go on (except when all of the lights are on). We thought it did go on before. What part would need to be replaced if that identifies the problem?
3. Is there a simple way to check the heater circuit?
4. Is there a booklet for this model on repairs?
Thank you,
#4 Posted : Friday, November 13, 2009 5:58:50 AM(UTC)
Yes. It will make it a pain to repair
Does not really point to a specific part
Yes with a meter you can check the thermistor, the element and the hi-limit thermostat. They will probably all check OK since your problem is intermittent.
I can tell you that it is a Whirlpool unit but I have no way to cross reference the Kenmore number.
Since it is an intermittent problem the most likely cause is a loose or bad connection. I would check the heater and the thermistor connects. The door switches also but this is a bit of a long shot.
You will have to see if they fit snugly, that the pins/connectors are properly crimped and that they are clean. Also check the wires that go from the control board to under the unit.
I would also try the following.
Unplug the unit
Open it up
Clean the connector on the board and the connectors themselves. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
jklovell
#5 Posted : Friday, November 13, 2009 9:27:54 AM(UTC)
jklovell
Thank you for your recommendations.
