nchokie
#1 Posted : Friday, November 13, 2009 5:47:15 AM(UTC)
nchokie
The washer will spin a full load of clothes and water without draining the water. It happened once and then it worked fine. Now it will not drain at all (except when I get a bucket and wring out all my clothes). I'm checking for blockage in the discharge line. I can only think the pump is clogged or dead beyond that. Thoughts?
sidfink43
#2 Posted : Friday, November 13, 2009 4:27:41 PM(UTC)
sidfink43
Yep
Take off the front and clean out the drain hoses and pump, then put it back together and see if the pump runs when it is in the spin mode.
Here is the service manual for your machine which is a Frigidaire sold under the Sears Kenmore label.
http://frigidaireservicetips.com/pdfs/488_3.pdf
