AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
soap dispense doesn't work after control module replaced
Our dishwasher control module was just replaced under warranty and ever since the soap dispenser cup will not open. There was never a problem before and the spring does work. The cup opens fine manually. Is it possible he installed the wrong one, didn't do the right programming or I have a faulty module?
Originally Posted by: jodysanderson  Our dishwasher control module was just replaced under warranty and ever since the soap dispenser cup will not open. There was never a problem before and the spring does work. The cup opens fine manually. Is it possible he installed the wrong one, didn't do the right programming or I have a faulty module? Usually the repair comes with a short warranty period following the repair. Could you just call them back? Of course trying to prove that the control module has anything to do with your new problem... Sorry I dont have better answer, but I'm sure someone will- please post results.
Dishwasher Repair
