shaunason
#1 Posted : Tuesday, November 10, 2009 7:27:02 AM(UTC)
shaunason
The cancel/drain light was blinking on my dishwasher. The only cycle that would function was the drain cycle. I replaced the console assembly (touch pad) per site troubleshooting. The drain light still blinked as before. I then replaced the electronic control assembly. I ran a short cycle and it stoped mid cycle and is now blinking as before. Do I have a defective electronic assembly or is the problem elsewere? p.s I'm new at postings.
#2 Posted : Tuesday, November 10, 2009 8:17:29 AM(UTC)
Need the last 3 digits of the model number (BL0 etc.)
Then I may be able to find a tech sheet that gives a pin-out of the keypad.
Your problem may be a stuck key.
shaunason
#3 Posted : Tuesday, November 10, 2009 8:32:49 AM(UTC)
shaunason
denman the model number is kudmo1tjwho
shaunason
#4 Posted : Tuesday, November 10, 2009 8:36:33 AM(UTC)
shaunason
denman-the model number as best as I can do is kudmo1tjwho--the keypad is new also
#5 Posted : Tuesday, November 10, 2009 12:22:59 PM(UTC)
Here is the tech sheet.
http://www.servicematters.com/d...0Sheet%20-%208269519.pdf
Sort of got me stumped.
It is not that uncommon to get a defctive parts but it is very uncommon to get the same error when you have replaced bothe the control and keypad.
I would check the keypad with a meter.
And try to dun the diagnostics.
