elainegina
#1 Posted : Friday, November 6, 2009 11:40:58 AM(UTC)
elainegina
Can anyone help. My dishwasher is not getting hot and as it progresses through the cycle it seems to just be washing all the time and does not stop at the end of cycle. When I stop and open the dishwasher is cold and the contents are not clean. Could it be the thermostat as my washer is a cold fill. It is a counter top so it has only a small capacity. I have tried to clean with the distilled vinegar as suggested on a blog for another make of dishwasher, but to no avail. Hope someone can help me, Kind regards Elaine
sbk101
#2 Posted : Monday, November 9, 2009 5:26:52 AM(UTC)
sbk101
read the thread above titled bosch dishwasher troubleshoot manual
and this one Bosch Dishwasher Stuck on 2H.
I think your symptoms fall in line with the ususal running on forever-water not getting hot-etc Bosch problem even though you have a different model number. I think it is the circuit board. On mine a solder connection was burned out. If you can look at your control module/circuit board you will be able to check if that is it.
I soldered mine and it is working again -for now.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
