rvt2004
#1 Posted : Wednesday, November 4, 2009 6:07:56 PM(UTC)
rvt2004
Knob To Control Water Level Appears To Be Stripped And When You Turn Washer On It Starts To Wash With No Water In It
sidfink43
#2 Posted : Friday, November 6, 2009 10:00:48 AM(UTC)
sidfink43
Sounds like your water pressure switch will need to be replaced, but first check to make sure the tube from the switch to the tub is clear and unblocked.
If it is ok, then replace the switch and see if that does not solve your problem. If it does not, then the timer is the next suspect.
Washer wont fill with water (Washer Repair)
by john1955 10/17/2013 5:20:51 AM(UTC)
washer wont fill with water (Washer Repair)
by amtracker 6/16/2012 6:24:53 PM(UTC)
Washer KUDG25SHWH1 wont fill with water (Dishwasher Repair)
by iamracerexx 3/6/2012 6:16:35 AM(UTC)
washing machine wont fill with water to finish rinse cycle (Washer Repair)
by kryzat 2/13/2012 6:12:07 AM(UTC)
by ron2011 10/16/2011 6:49:30 PM(UTC)
Frigidaire FDB956RBC1 wont fill with water (Dishwasher Repair)
by bob80man 10/21/2010 9:48:30 AM(UTC)
Maytag washer wont fill with water (Washer Repair)
by volguy 6/14/2009 6:33:24 PM(UTC)
ice maker wont fill with water (Refrigerator & Freezer Repair)
by duramax100 9/12/2008 2:37:40 AM(UTC)
Whirlpool washer wont fill with water. (Washer Repair)
by dfwhip 12/10/2007 8:03:07 AM(UTC)
