My GE QuietPower is a little over 2 years old now - Today I started experiencing my 2nd drainage issue. The first was solved by unplugging the airgap on the sink, but todays drainage problem doesnt involve dirty yellow water, its mostly clear water. I checked the air gap and there were no ubstructions. Inside the washer I pulled off the water blade and removed the grill above the drain and reach as far as i could,I found a few pieces of pineapple but nothing huge.
What should I do from here?
Thanks in advance
A Model Number may help others help you.
If it is draining out some but not all the water a common problem is the "Piston and Nut" valve which is under the cover, inside the tub, at the back of the machine.
If it is leaking water recirculates back into the tub instead of out the drain. |
THIS FORUM IS DEAD!!!!!!! |
The Model # is GLD4500N00BB
It does not look like your unit has a "Piston and Nut" |
