herbh
#1 Posted : Monday, November 2, 2009 9:28:16 AM(UTC)
herbh
I have a GE profile gas cooktop model JGP963bec2bb and have to replace the top left igniter . How do I open the coo top to gainaccess to this part . Must I remove the entire cooktop from the counter or can it be accessed from the top without removing it ?
#2 Posted : Monday, November 2, 2009 5:49:57 PM(UTC)
It is pretty simple with this model - just remove the burner base and pull the igniter up.
- The igniter Part number: AP3191250
herbh
#3 Posted : Tuesday, November 3, 2009 4:35:19 AM(UTC)
herbh
Gene,I apologize, I amreplacing the left rear gas valve and cannot see a way to gain access to it without removing the entire cook top from the counter.
#4 Posted : Tuesday, November 3, 2009 2:09:53 PM(UTC)
You have to remove all knobs and the burner bases. Then remove the top panel. You can see it on the diagram.
- The left rear gas valve Part number: AP3186120
herbh
#5 Posted : Wednesday, November 4, 2009 4:52:50 AM(UTC)
herbh
Thanks so much for your help.
#6 Posted : Wednesday, November 4, 2009 12:09:33 PM(UTC)
